Napco GEM-P1632 Easy Menu Mode
K
Knight Houston
I am having trouble geting to the easy menu mode. On Page 47 of the
install manual it shows the easy menu mode. I am trying to access the
area of "# of zns in Area!1*" "Exit/Entry Zones, Interior Zones, chime
Zones,
I am able to get to the date, time, dealer code, zone descriptions, and
so on it shows repeat arrows in the area I can access.
I can also get to the direct address part but I do not know any address
locations
thanks for any help
Knight
Bob La Londe
A lot of stuff is only accessible the first time you enter the easy menu.
After that you have to go to address programming or use the PCD software.
K
Knight Houston
Bob La Londe
Fishing Arizona & The Colorado River
Fishing Forums & Contests
http://www.YumaBassMan.com
is there a address guide ?
K
Knight Houston
I am also have a fault in zone 8 with a resistor in line. when I hook
up common for 7 and 8 I get a fault in both zones .... not
understanding... is there a factory reset button?
Bob La Londe
Zone 7/8 is common/seven/eight not seven/common/eight like the other zones.
Also, there are two jumpers on the board for seven eight which set them as
either two wire fire or burg zones.
They do not wire the same for fire as burg. There is a wiring diagram on
the door of the panel.
Also, there should be address programming in the programming manual.
K
Knight Houston
that was it ..... I did not pay attention to the wiring diagram !!!!
