Alex
- Jan 1, 1970
- 0
I have a NEC V920 19" monitor which seems to have a faulty flyback.
It was occasionally (once every couple of weeks) arcing internally
somewhere - a quick, short arcing sound could be heard, and the screen
would noticably dim for a short time.
Late last week it became quite frequent (a few times a minute), and
finally a long arcing sound, and then the screen went blank.
The monitor seems to make all the normal sounds when turned on (you
can hear the relays clicking), and the power light under the switch
turns on (the power supply seems to be working), but there is no EHT
being produced by the flyback (tested by placing an earthed
screwdriver near the EHT connection on the side of the tube, under the
rubber boot. No discharge. In fact, the screndriver can touch the
metal connection, and no discharge is observed).
I've measured the voltages on the PCB connections to the FBT (T302),
and there are five connections at ~120VAC, five with 0V on them, and
one connection with 24VAC present. Without a schematic, I can only
assume that this indicates that the FBT is being supplied with the
correct voltage, and it has become open circuit internally.
Is the flyback a common fault in these monitors?
Are there any other tests I should perform before replacing the
flyback?
Is it economically viable to replace the flyback in this monitor? (Or
cheaper to buy a new one?)
Where is the best place in Australia (Perth) to buy a replacement
flyback?
The flyback has the following codes on an attached sticker:
H0003931
F94056A F-801
MERITRON
CT-8733 00806A
Alex.
Alex.
flyback?
flyback?
H0003931
F94056A F-801
MERITRON
CT-8733 00806A
Alex.
Alex.
