Need a comparator but don't have one?
cjdelphi
Oct 26, 2011
1,166
I've only ever built this once, but it did the job....
WHONOES
May 20, 2017
1,242
I have used opamp's as comparators. They usually require a bit of hysteresis via positive feedback to work correctly otherwise they can have a tendency to oscillate at the point of transition. As for speed that depends on the device used. But, yes proper comparators are preferable and easier to implement.
Alec_t
Jul 7, 2015
3,818
If the comparator switching threshold isn't critical you can just use a single Schmitt trigger gate, e.g. CD40106, with its input resistively biased above/below the inherent threshold as required.
danadak
Feb 19, 2021
1,091
One drawback of CD40106 type of logic parts is they have a very low
trip accuracy for a specific valued voltage, eg. no good Vref to compare
against. As well as wide sensitivity to supply V and Temperature. You can
get comparators today with onchip Vref to solve that issue.
Regards, Dana.
