amdx
- Jan 1, 1970
- 0
I'm looking for a transducer and preamp to record audio up to 50khz.
Seen any circuits or transducers for this bandwidth?
Mike
Mike
http://www.bksv.com/Products/TransducersConditioning/AcousticTransducers/Microphones/4954.aspxI'm looking for a transducer and preamp to record audio up to 50khz.
Mike
That's very nice, ordered two, oh wait $1,954.00 each. Cancel that order!Martin Griffith said:
Neither, I want to record vibrations of air molecules up to 50khz.Phil Allison said:"amdx"
** You have made two mistakes already.
The term "audio" refers to an * electronic signal* with band limits the
same as the ( human) audible frequency range - ie 20Hz to 22 kHz.
So - do you want to detect and record only supersonic sounds OR do
you want to be a total wanker and extend the audio band to supersonic
frequencies for audiophool reasons ??
Phil said:"amdx"
So - do you want to detect and record only supersonic sounds OR do you
Any idea what the panasonic electrets mics are like above 20K?"amdx"
...... Phil
Phil said:"amdx"
Tssk @ you Phil.
That's "ultrasonic". Made the same mistake myself before of course.
Maybe he wants to record bats ?
BobG said:The piezo tweeter horns come in about 2K and up go to about 40khz
amdx said:Neither, I want to record vibrations of air molecules up to 50khz.
Thanks for the clarification, all without name calling. Well, "wanker"
but that doesn't even register when coming from you.
Mike ;-)
Are you saying you want to record the thermal noise of the air?
No, just getting info to record sound from 20 hz to 50 khz, the source
of sound would be a muzzle blast. This seems to be an inexpensive solution
get the frequency response.
http://www.linkwitzlab.com/sys_test.htm#Mic
Where is the luck needed Phil?** ROTFL !!
Lotsa luck - pal .
...... Phil
I don't see that the article says it is flat to 50khz it also doesn't sayPhil Allison said:"amdx"
"Phil Allison"
** God, you are so dumb.
Where does it say that electret capsule is flat to 50kHz ?
Where does it say it can handle the huge SPLs of a gun shot ?
Something between a .22 and a .44.BTW What is this "muzzle blast" ?
What a fucking, know nothing WANKER !!
it isn't flat to 50 khz.
The original info I received said the modified WM-60AY had a frequency
response from 20 hz to 66 khz, but it didn't say +/- 3db, +/- 10db or +/-
30db so it does lack some detail.
Why this need to degrade and name call that comes through in almost all of
your posts?
The original info I received ...
The article doesn't say anything about SPL's of gun shot.
It says the modified WM-60AY can swing 5vpp max at 141db SPL. I don't know
if that is enough, but I suspect the distance can be adjusted to reduce
the SPL.
Can you add anything that will help the project?
of your posts?
