Need Bare PCB with XC9500 PLD in PLCC84 Package
James Morrison
Hello everyone,
I need a cheap and dirty board to program a small quantity of XC9500
PLD's. I have all the software and programming cables I need and I have
other boards for other packages but I don't have the PLCC84 packge.
So I need a bare PCB with footprints for a XC9500 PLD in the PLCC84 and
its JTAG pins connected to a header of some sort. Obviously it will
need power inputs as well but I can solder what I need on.
Does anyone have something like this laying around the lab that they'd
like to get rid of? I will certainly pay for shipping and a small price
for your troubles.
Thank you. Feel free to reply directly to this email address.
Tam/WB2TT
James Morrison said:
Hello everyone,
for your troubles.
James,
You are supposed to put the header on your target board. Then you can make
changes and improvements later, if required, and don't need a socket.
Tam/WB2TT
James Morrison
I realise that is the normal course of action. However I have done a
PLD design for a customer and he would like some programmed chips sent
to him so he can incorporate them into a board that he designed.
If I can have the chips arrive at the same time as the PCB's then it
saves him some time.
I can hand-wire together this board if necessary but if I can pick up a
spare board then I can save myself some time.
N
Nico Coesel
Hello everyone,
How about a vero board, solder a PLCC84 socket onto it and wire it for
programming?
Tam/WB2TT
Hi James,
There are 84 pin PLCC sockets with pins on the bottom on 100 mil centers.
You could put that on a Vector board with a few bypass caps, VCC and GRD
connections, and the header. If you are not going to test it, I think you
can leave all the IO pins floating. BTW, I bought such a socket from Mouser
for about $2 for use with a 95108. Using a board meant for a different use
could cause problems. For example, you might want to program an IO pin as an
output that the board has hard wired to VCC or GRD.
Tam
Munir Mallal
Hello everyone,
How about this:
http://www.awce.com/pbx84.htm
Munir
Leon Heller
Hello everyone,
for your troubles.
I've got a PCB design here that will do what you want:
http://www.geocities.com/leon_heller/pld_starter.html
The artwork file is available, so you could easily make your own PCB.
Leon
