Need Help can't understand the parts
pyroboy
Mar 25, 2006
20
Hi, I am new to electronics so don't shoot, I really want to learn
I am trying to copy this but I can't make out some parts
take a look
2old4digital
What is this curcuit for? Are you try'n to fix or copy?
pyroboy
Mar 25, 2006
20
I am trying to copy it, I have already made the PCB!  :)
It's a voltage inverter. It came with two cold cathode lamps.
It takes 12v and it gives 680v I think but I am not sure about the last one.
SM2GXN
Feb 18, 2006
161
Hi pyroboy!
The component that are marked as capacitors are probably ferrite beads and they are used as filters but there is two disc ceramic capacitors one each side of these beads, if there is a white ring around them it is diodes but I can't see any on the picture,
The black thing is an inductor probably used as filter too, together with a capacitor it will make a lowpass filter, maybe for the dc voltage into the pcb.
A small high voltage transformer like that is not easy to wind, you'll need a very very thin wire  ;)
pyroboy
Mar 25, 2006
20
I m trying to learn but I have to learn the the small parts first and then I will make my own transformer.
What kind of characteristics does a transformer have?
How will I ask it from the "electronic" shop
