need help electronic/relay problem phone horn
Status
Not open for further replies.
georgebaker1
Dec 19, 2021
I need to ring a phone that activates a loud ass horn. Phone has no audio ports. I'd be tapping into the 2 wires that connect from phone circuit board to the phone ring speaker.
Inside the handset, the 2 wires show .035-.045 VAC (probed with multimeter while the phone "rings") and connect to an 8 Ohm 2W speaker inside the phone. This 8 Ohm 2W speaker needs to be replaced with a very loud horn or buzzer.
-I purchased a generic 12VDC piezo horn. Need to feed it 12VDC when phone rings. That's all.
I'm stumped. Low signal relay? Some type of inline amp? I can solder a bit, and have only a very basic understanding of this stuff.
Do I look for a low signal relay? like .03VAC to 12VDC?
Thank you
HarryA1
Mar 4, 2009
481
As you have posted this question on numerous forums I will leave it up to them to answer your question. Good luck.
HarryA1
Mar 4, 2009
481
Search on the internet for "need help electronic/relay problem phone horn". As he posted this on 5 or 6 other forums you may find useful information there.
JohnKlein94
May 20, 2022
3
-I purchased a generic 12VDC piezo horn. Need to feed it 12VDC when phone rings. That's all. To protect my device, I use https://celltrackingapps.com/how-to-find-someones-name-by-phone-number-for-free/, where I can also find information on how to find someones name by phone number.
Thank you
I think for safety's sake it's advisable to find one.
Debra Lee
Jul 6, 2022
3
Look up "need help electronic/relay problem phone horn" on the internet. You might find some helpful information there because he posted this on five or six different boards.drift boss
billyroberts
Nov 7, 2022
If you decide to hire an in-house team, you will need to provide them with a physical location to work in. In many cases, the team will work in the same building as the startup's employees. Having a physical location where the team can meet and share information is important.
If you want to hire an in-house team, the recruitment process can be a lengthy and grueling one. You'll need to make sure that each member of the team in northell.design is a fit for the project. However, you will be able to avoid a lot of the pitfalls that come with hiring outsourced development teams.
Thank you
Take either (or the other) wire(s) of the speaker, and then measure the voltage once more. For accuracy, you should take two measurements: one using the meter set in AC mode. The other another using the meter in DC mode.
Status
