Need help for xmas project!
McCallister1
Dec 13, 2011
Hi all,
New to the forum & need some guidance for a Christmas project I started not knowing it would end up getting this in-depth...
Anyway, I am making a "manly" garage wall frame type thing for my Dad. I want to have the backside of this frame back lit with LED strips. I want to run one strip of green colored LED lights on the top edge and then one strip of yellow LED lights on the bottom edge. I was looking at getting some 5050SMD lights(one of each color). They are 12v DC products.
I want to be able to run these off batteries so there are no cords to mess around with plugging into an AC outlet. The site I was looking at buying them from says a 19.5 inch length of each(30 LEDS per strip) has the following:
Green: draws 500mA(6 watts)
Yellow: draws 600mA(7.2 watts)
What would you recommend I use for a power supply? I was thinking two 9 volt batteries together(18 volts)& then using resistor(s) in a series as someone with more knowledge than I recommended. Of course I'd want a simple switch in there too. Can I run both strips on the same power source?
I really don't think this is a complicated task for most who know what they are doing & hoping to get a bit of guidance to get this completed. I am pretty good at hands on, but just want to be sure I don't fry out $35 of LEDS.
Thank you in advance!
jackorocko
Apr 4, 2010
1,284
You have to use resistors to control the current. Those LED's will drop 12 volts@wide range of current. If you do not use a series resistor the LED's will draw too much current and toast themselves.
I think your series resistors are gonna need to be rather big as well, if they need to drop 6V at .5A that is equal to 3 watts of power. Seems like a waste when using batteries.
I also don't think you are gonna get much run time out of (2)9V battery (if even possible, I can see the battery getting extremely hot.) They have good voltage but very low current available. About 1/4 of a AA http://www.techlib.com/reference/batteries.html
McCallister1
Dec 13, 2011
Thanks for the input. As you can see I have very little knowledge of the proper set up for this. I really want to not use AC for aesthetic reasons. If 9v batteries are not a wise choice, what would you recommend for a DC source that will not drain super fast and not get very hot as you stated? Thanks!
alfa88
Dec 1, 2010
349
One of the things I pondered as a child when watching Star Trek was their phaser pistols and what kind of marvelous power source was contained in them. Fast reverse to 2011. I think the smallest and best you'll be able to find are lithium( not to be confused with di-lithium; sorry, Star Trek humor) AA cells but they come at a cost and also die out eventually.
