Need help on a socket's PCB footprint
Chengjun Li
Oct 21, 2014
84
I want to put a OTS-16-1.27-04(SOP16) on my pcb, I use eagle cad to design the PCB. I first search the internet and couldn't found any library which contains this component. Then I try to build the component's schematic and footprint by myself. I met a problem when trying to draw the footprint of the component. The component's datasheet doesn't give clear information about the pins assignment(16 pins position and two holes position). I found one online shown below, upload_2015-1-11_12-18-57.png
but the dimension (20mm in horizontal direction) is contradictory with dimensions list in the datasheet. I feel very confused and hope somebody could help me. Thanks. I attached the datasheet.
  • SOP_Enplas.pdf
Do what I do and measure the actual device to confirm
Calmore
Jan 19, 2015
28
Design the footprint and print it 1:1 on a piece of paper. Does it look realistic, allowing for tolerances of the printer?
