Need help with simple relay time delay circuit
phila
Could some of you give me some input.
This is a project on my boat.I have a momentary micro switch on my
shifter linkgage that when triped it grounds the neg. side of the
ignition coil which stumbles the engine long enough to shift out of
gear. The switch when tripped goes to ground.I need to build a simple
circuit to hold the coil to ground for 1 to 2 secs to give it more time
to shift.
I was thinking of using a 12 volt relay with the switch wired to to the
ground of the relay and a cap on the positive side of the relay to
delay the relay.
Thinks for any ideas.
