Need help with sourcing a resistor for a Peavey XR800F Plus
Mk1Jordan
Jun 7, 2024
Hi everyone. I picked up an old Peavey XR800F Plus that doesn't work and have stripped it down and found that the resistors have been burnt out. Managed to find a schematic for it but can't seem to make anything of the information that is provided. The key for the parts are as follow...
QTY - PART NAME - VALUE - PART NUMBER - DESCRIPTION AND DEVICE DESIGNATIONS
The part i am looking for is listed as...
16 0.22W5 0.22W5 70241102 .22--5W--5%--WW--AXL
If anyone can help me find the resistors i am looking for it would be more than appreciated.
Thanks for any help.
Delta Prime
Jul 29, 2020
2,996
0.22 Ohm
5 Watt
5%=J
WW=Wire Wound
AXL=Axial
Cement resistor=that's my guess
Or aluminum clad
Or even ceramic no photo.
Digi-Key,mouser ,element 14.
That is where I source electronic components.
Mk1Jordan
Jun 7, 2024
Thanks for the replies everyone. I've attached the schematic aswell as some pictures of the burnt out resistors to hopefully help identify what they are as they dont look like the ones mentioned by Delta Prime.
Also found another resistor that appears to be burnt out which is listed as this one the schematic if someone could help me understand what i need to get
6 150S 150 70200014 150---1/8w--5%---smt
Thanks again for all the help!
  • Peavey-XR-696-XR800F-Power-Amp-Schematics.pdf
Delta Prime
Jul 29, 2020
2,996
Definitely old school .Desolder them measure the resistance
You have to clean up that board.
Wear gloves that heatsink compound is toxic to humans.that is no joke!!!
Sorry about the bold. I'm hiking .speech to text stupid phone.
Same same....they appear to be ballasting resistors for the output transistors to avoid thermal runaway.
I'd be searching for a couple of blown output transistors.
Ylli
Jun 19, 2018
411
When you post excerpts from the parts list, it would help if you would let us know what resistor you are talking about. In this case it could be R130, R140, R230, R240, R270, or R273.
The 0.22 ohm resistors you mentioned could be some or all of these:
This appears to be a Class H amplifier. They can be a little more tricky to troubleshoot. I would suggest removing a testing transistors:
Q100, Q101, Q102, Q107, Q108, Q110, Q114, Q115, Q116, Q119, Q120, Q121.
Actually yes, but in this instance it is clearly visible at being R137.
Ylli
Jun 19, 2018
411
The first one (without a visible designation) doesn't look too good either.
