Need help with troubleshooting AC ELectric Motor
Clive
Gentlemen (and Ladies) -
Helping out a friend. Craftsman 10" radial arm saw. Was told it
worked when put away. Now the motor hums when turned on. Giving it a
little push gets it turning slowly.
The 120V motor has a very slim profile. I found a capacitor external
to the motor. Replacing it made no difference. I also observe that
the wiring from the motor (3 leads, wht, blk, red) as well as the AC
from the on/off switch and the capacitor connect to a square gadget
with spade lugs. The L1 line apparently goes through a heavy wire
coil that bridges two of the terminals, to what I assume is the run
winding lead of the motor. (blk)
This gadget has a marking "3CR 118 931". I would like to know what it
is and also the likelihood of it being the problem. There isn't much
to it, I don't know if it is actually anything more than a terminal
block.
If it will help I can scribble up a wiring diagram or even attach a
photo of the device.
Regards - Tony
H
Homer J Simpson
Possibly a PSC motor with one burned out winding.
James Sweet
block.
Regards - Tony
Have you looked into getting a manual from Craftsman? Most decent power
tools have replacement parts available and the manual will show what
everything is.
Clive
The "gadget" turned out to be a motor start relay. The start winding
was not getting switched in. Google up "3cr motor start relay" if you
are curious.
Thanks for taking the time to respond.
- Tony
