[email protected]
- Jan 1, 1970
- 0
In the process of acquiring parts for:
http://usbirboy.sourceforge.net
and trying to determine what type of diode is needed and where to
locate/purchase.
I am a beginner at building these types of things. I am unsure if I
need a full-wave rectifier (4 diodes) or half-wave
(1 diode).
Wondering if this diode is usable:
1N4004 400V 1A General Purpose Silicon Diode
The defacto standard in rectifier diodes.
Forward Current: 1A
Surge Current: 30A
Forward Voltage: 1V
Package: DO-41
Reverse Voltage: 400V
http://store.fundamentallogic.com/ecom/index.php?main_page=product_info&products_id=37
Also trying to figure out if a condensator is the same thing as a
capacitor. (In need of two 22pF condensators and four 100nF
condensators, and it appears that the two terms are used
interchangeably.)
For example:
http://www.sunrom.com/index.php?main_page=product_info&products_id=492
Details
Multilayer metallised polyester film capacitors that are epoxy resin
sealed in a flame-retardant thermoplastic case.
These low-cost capacitors have a high CV to volume ratio and are
highly reliable and stable over a very wide temperature range (-5 C to
+100 C). The capacitors are non-inductive with a standard 5mm lead
spacing and are primarily intended for PCB mounting.
Suggestions?
Thanks....
locate/purchase.
(1 diode).
Forward Current: 1A
Surge Current: 30A
Forward Voltage: 1V
Package: DO-41
interchangeably.)
For example:
Details
Suggestions?
Thanks....
