Billy
- Jan 1, 1970
- 0
I need to amplify a small signal coming from a temp sensor. The temp
sensor has an output voltage range from 0V to 1.5V. I want to
interface the temp sensor to A/D converters on a micro-computer, so I
would like to use the full 0V to 5V range of the micro. So, I want to
amplify the temp sensor signal by a Gain of 3.3 in order to get a 0V to
5V range. I want to use an op-amp in a non-inverting configuration for
this gain. My problem is that when I used a 741 op-amp I didn't get
the correct output when my signal was near ground (ex.1mV to 500mV). I
was told this was because the 741 doesn't operate well near it's
voltage rails, which in my case are 0V and 12.6V (car battery). So I
tried an LM324 single power supply op-amp, which gave me better
results, but the linearity on the op-amp wasn't the greatest. Instead
of a Gain of 3.3, I got a gain close to 3.7 or so. I was wondering,
does anybody know of a better op-amp with good linearity that can
operate on inputs very close to ground and give me correct gain values?
Thank you very much.
