Need replacement of NEOSID Ring Core
Rleo6965
Jan 22, 2012
585
Hi, This time I need your expertise finding equivalent of NEOSID 17-732-22 Ring Core 14.8X8X6.35mm. I think its now obsolete part.
I need this core as filter choke to avoid 22khz spike from center tap of push pull transformer going back to 12V Car Battery.
I have already build this dc inverter and working properly and I temporary use core from ATX PSU and wound 12 turns of 1 mm enameled wire to have 6.5uH filter choke inductance.
Now my problem was I need 10 pcs of equivalent or replacement of NEOSID core. After googling. I found out that NEOSID 17-732-22 have a Grade=2003, Saturation Flux Density=15,000 gauss and Max Freq = 500khz.
I search in RS and I don't know the equivalent MATERIAL to be able to search correct Ring Core equivalent basing those I mentioned above. I only need the correct core only.
http://philippines.rs-online.com/we...-by=default&sort-order=default&view-type=List
Here's the link about core material
http://www.universal-radio.com/catalog/misc/amidonT1.html
As I mentioned before. I'm not graduate of any Electronic Engineering Course. I'm self study electronic engineer. :D This the reason I need your expertise.
Rleo6965
Jan 22, 2012
585
Just figure out correct material after researching in internet and its not available in RS and Farnell.:(
