Need signal generator help.
Explorer
Mar 28, 2014
102
I'm not sure how to output a "modulated signal" from this little signal generator module that I have. The manual is in VERY broken English!
But, thanks for all your help and info, Duke!
duke37
Jan 9, 2011
5,364
Even if the signal is not modulated, you can use it.
Tune to a radio station, twiddle the generator around 450 to 500kHz and you will hear a whistle when the generator is close to the IF that the station is generating.
Explorer
Mar 28, 2014
102
Well, I've put together 2 test tank circuits, and, by calculation, I feel certain I know what their resonant frequencies should be. And the little Robert Brown Frequency Finder agrees wholeheartedly. (I added a 2nd diode to that circuit, just across the banana plug jacks, cathode to the side that Brown labels as positive in his circuit diagram.) I am even able to get a good sense of "Q": the meter needle creeps up to a peak with one of the tank circuits, and then slowly creeps back down; while, with the 2nd tank circuit, the needle sort of goes BING! all of a sudden.
I've realized that the Rufus Turner Dip Adapter dips in all the same places, no matter what I put it next to: round about 360, 430, 560, 770, and 1250 kHz.
The capacitance clip that I made for my Lodestar DM-4061 Dip Meter (as described above) isn't doing anything for me. I put the dip meter next to my shortwave radio and it seems to impact the reception in all the right places, as I hit the scan button on the radio. But, I've yet to see this dip meter do anything meaningful next to a parallel coil/cap combo. So, I really have no idea what it's good for.
The exploration continues...
