K
kidkv
- Jan 1, 1970
- 0
Johnny said:<snip>
When you say "8.50v out thats on and off", what exactly do you mean?
(You need to describe things more clearly)
Do you mean that a measurement from ground to the collector of Q205
shows 8.5V whether or not it's turned on? ie With the output of U201C low
and 0V at the base of Q205, the collector measures 8.5V and with the output
of U201C high, the collector is still at 8.5V and the base is at 0.7V?
The part about a jumper from collector to emitter loses me. How would
that turn the transistor on? Or did you mean that the relay would turn on?
Again, I have to re-iterate that you have to describe things more
accurately if you want help.
... Johnny
this is true
a jumper from collector to to emitter or gnd would kick the relay on
then it would stay on for some time and then after maybe 2 to 5 mins
the relay would drop out. it's like the darlington's are on for some
time when i do that.
i have only one 5v trace on the board???? i know that i have 5volts
from the power supply but at the last chip i get 4.50v
darlington's are npn
does this help out more?????
