Gazz
- Jan 1, 1970
- 0
i have a LCD television that runs on 12 volts, it's sold to be used at home,
via the supplied switched mode psu, this gives out 12.33 volts at upto 4
amps,
i bought this tv to be used in a motorhome, where main will not be an option
very often, but the main power source is a few 12 volt lead acid batteries,
no problems you'd say.. just connect the tv directly to them,
someone i know did just this with his tv.. exact same one as mine, and it
was fine when on battery power alone, it even worked right down to 10.5
volts when he stopped dishcarging the battery bank to protect them.. no CRT
12 volt tv will do that,
However when he plugged into the mains to bring the battery charger on line,
hi TV got smoked, litterly, after having it on for 20 minutes smoke poured
out of it, and it died,
his charger gives out 13.8 volts max, and it seems these TV's are designed
to only take the 12.33 volts their mains psu gives them, they werent
designed to run in an automotive enviroment it seems, where the voltage can
range from 14.8 volts down to 10 volts,
i still want to use my tv in my van, and my mains charger is a higher output
version than his.. mine will be set to give out 14.4 volts for 2 hours to
equalize the battery bank,
also the engines alternator will bring the terminal voltage upto 14.4 volts
when it's running, so anytime i'm on shore power, or have the engine
running, i risk blowing an expensive TV,
I've been searching for a voltage regulator that will keep the voltage the
TV see's to no more than 12.33 volts..ever, but obviousely this is fine when
the engine or charger is on line and i have higher voltage than a battery on
it's own, but once off charge, the terminal voltage of the batteries will be
12.8 volts and will drop as they get discharged, so i was looking for a
regulator that would drop out of the circuit when it couldent keep the
voltage at the set level, seemed hard to do without having it drop out at a
higher than 12.33 volts.. as the regulator needed to have an input of at
least half volt above the output voltage,
I've just found out a little about buck - boost converters tho, would one of
these do the job for me?
http://www.linear.com/ezone/1625.html is the page showing a circuit that's
more than a basic buck - boost converter apparantly, this one can handle 3.3
amps max, i really need one to handle 4 amps max.. idealy 5 amps so i can
run the 12 volt DVD player off the same unit.. just to be safe,
my knowlage is limited of electronics, simple voltage regulator circuits i
have built, led arays using pcb's i make my self no probs, but like the
mosfet switch i was asking about in my last post, i seem to be getting out
of my depth here,
can someone tell me if a buck - boost converter is what i need, will it
consume a lot of power when in use.. i guess this is one place where i'd
rather use power to save the TV from getting dammaged, than save a few
milliamps of drain so i can get another few minutes out of my battery bank
Anyone point me to a better circuit diagram for one that will give me 12.33
volts out from 10 to 15 volts in, and at 5 amps idealy, oh and have a clean
output that won't affect the TV or it's tuner.
Cheers,
Gazz
amps,
of my depth here,
Cheers,
Gazz
