Need to supress 0.5sec pulse for 0.5sec, then output
yamajason
Oct 12, 2015
I have a Directed Electronics Passive Keyless Entry, it flashes the Parking Lights for
0.5sec ON,
0.5sec OFF
0.5sec ON
OFF
I want to Ignore the 1st Pulse ON (which signals Locked) and only output signal on the 2nd Pulse (which signals Unlocked) this will Drive a Pulse Timer Relay.
The Parking Light Flashes/Pulses are (-)12VDC with 200ma capability.
What would you recommend?
Alec_t
Jul 7, 2015
3,818
Welcome to EP!
Why the negative sign? Are these signal levels normally high (+12V), going to 0V (or -12V) for 0..5 secs?
Are these already-debounced signals, or are they from mechanical switch contacts (and so would need debouncing as a preliminary step)?
yamajason
Oct 12, 2015
The (-)12VDC is really +12V going to 0V ground from a chip. No debouncing required. Manual lists it as (-) output, but you're smarter than that. Thanks
Alec_t
Jul 7, 2015
3,818
Does the output signal have to last 0.5 secs too?
What sort of signal (volts, current) is the Relay expecting?
GPG
Sep 18, 2015
452
Does the central locking have a locked/unlocked indication signal?
