Need Weller EC2001 Soldering Station Info
Jack_son
I am attempting repair of my Weller EC2001 Soldering Station. Doe
anyone have a schematic? The base unit has digital readout, an
adjustable temperature.
Just voltage and resistance readings on the 5 pins of station, and o
the EC1201A [or EC1201P] iron would be helpful. The 28 V output seem
OK, as is the on-board regulator.
Jack_so
Jim Adney
I am attempting repair of my Weller EC2001 Soldering Station. Does
anyone have a schematic? The base unit has digital readout, and
Just voltage and resistance readings on the 5 pins of station, and on
the EC1201A [or EC1201P] iron would be helpful. The 28 V output seems
I think I've got a rough wiring diagram at work. I'll try to remember
to bring it home.
IIRC, there is a NTC sensor in the tip that is fragile. If that is
open, the tip will overheat. I tried to fix ours, but gave up and
bought a new one for ~$55. A few years before that I had replaced the
temp control circuit in the base. There was nothing there that I could
fix, I just had to buy the whole module for ~$80.
If I had this to do all over again I would not have picked up that $5
station.
Get a nice used Weller WTCPx, fix what's broken, and use it for a
lifetime. Much cheaper, much nicer, much more reliable. Just take the
base apart when you get it and SOLDER the connector pins to their
wires.
BOB URZ
Jack_son
I pulled out some weller notes i had from work.
On the 5 pin connectors, pin 2 & 3 are the sensor and
pin 1 and 4 are the heater. the sensor was about 22 ohms
cold and the heater 28 ohms. If either set of terminals
reads infinite, you got a problem in the head or cable.
Mhound
My Email to you bounced.. I have tried to send you a reverse engineered
copy of a weller
2002 schematic. I hope it is similar. Email
me if you are interested. argyle1nospam@ nospamhotmail.com
(remove nospams)
