Negative charge pump
audioguru2
Apr 6, 2004
12,022
Hi Kevin,
What are you going to use the negative 13.3V for? ???
Car radio audio amp ICs don't use a negative voltage. ::)
Kevin Weddle
Feb 23, 2004
1,620
Yeah. I think the amplifier is a pushpull. The volume is adjusted internal to the chip. The amplitude of the input is taken into account and it drives the pushpull.
audioguru2
Apr 6, 2004
12,022
If the car radio is new, maybe it has an all-digital Class-D switching audio amplifier. They are so efficient that a small surface-mount package can provide 4 bridged amps without requiring a heatsink.
I don't want to touch those amplifier ICs because they have 56 tiny legs and their "power-pad" bottom is also soldered to the PCB. Try doing that by hand!
My car's factory radio/CD player must have 4 bridged amps because both wires for each speaker carry the signal. After replacing the crappy high-impedance tiny-magnet factory-installed speakers with half-decent 4 ohm big-magnet ones, I get more than enough power/volume.
Yeah, its volume control must be digital too, because you can turn it around and around. It must provide "up-volume" or "down-volume"
pulses using an optical or hall-effect sensor then stores the setting in memory.
