nesting a program with a bool statement
foTONICS
Sep 30, 2011
332
so I have this program that asks a user to enter a time(24 hour clock) and spit out the next available flight. the program works except for one thing: I've tried to get it to loop until a user chooses to quit (giving the variable <int action> a value of 2) but no matter the value of <action> the program terminates. Am I not looping this correctly? Here's the code:
// lab3q8.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#include <process.h>
//variables
int user_h,user_m,air_h,air_m,action;
//boolean operator (checks the user input for validity)
bool _valid;
//main program
int main(void)
//printf("TP1");
while (_valid==true);
//printf("TP2");
//system("clear");//clears screen upon each program loop
printf("Please enter a time (24 hour clock) in the following format (hh:mm)");
scanf_s("%d:%d", &user_h, &user_m);
if ((user_h<=24&&user_h>=0)&&(user_m>=0||user_m<=60))//this if statement checks if the user input is valid
if (user_h<=8)//this if statement determines the output
printf("The next available flight:\nDeparture\tArrival\n8:00a.m.\t10:16a.m.");
else if (user_h<=9&&user_m<43)
printf("The next available flight:\nDeparture\tArrival\n9:43a.m.\t11:52a.m.");
else if (user_h<=11&&user_m<19)
printf("The next available flight:\nDeparture\tArrival\n11:19a.m.\t1:31a.m.");
else if (user_h<=12&&user_m<47)
printf("The next available flight:\nDeparture\tArrival\n12:47p.m.\t3:00p.m.");
else if (user_h<2)
printf("The next available flight:\nDeparture\tArrival\n2:00p.m.\t4:08p.m.");
else if (user_h<=3&&user_m<45)
printf("The next available flight:\nDeparture\tArrival\n3:45p.m.\t5:55p.m.");
else if (user_h<7)
printf("The next available flight:\nDeparture\tArrival\n7:00p.m.\t9:20p.m.");
else if (user_h<=9&&user_m<45)
printf("The next available flight:\nDeparture\tArrival\n9:45p.m.\t11:58p.m.");
else
printf("I'm sorry, but you have missed all available flight times for today; please try again tomorrow morning");
printf("Would you like to run this program again?, key \"1\" for yes and \"2\" for no");
scanf_s("%d", &action);
if (action=2)
_valid = false;
else
_valid = true;
else
printf("Please enter a valid format/time, please execute this program again");
_valid==false;
system("PAUSE");
return 0;
14,317
I see a few issues:
1)
Code:
bool _valid;
//main program
int main(void)
//printf("TP1");
The variable _valid is not initialized before you first use it. Add _valid = true before the while statement.
2)
Code:
if (action=2)
This is not a comparison but an assignment.
use
Code:
if (action==2)
3)
Code:
if (action=2)
check the value of action. Is it really 2? Use a debugger or add a debug-output between these two code lines.
4)
a tip: shorten the code to get the loop running as required:
Code:
#include "stdafx.h"
//variables
bool _valid;
//main program
int main(void)
_valid = true; // my change, see above
//printf("TP1");
   printf("%d\n", action); // debug output added by me
   if (action==2) // my change, see above
       _valid = false;
   else
      _valid = true;
return 0;
foTONICS
Sep 30, 2011
332
these are very useful hints, ill make those changes and let you know how it turns out
-thanks again!
14,317
Code:
if (action=2)
_valid = false
Not only is this an assignment of the value 2 to the variable action, moreover the result of this assignment is generally true so _valid becomes necessaryily false and the loop is terminated after the first run. This is the real problem, apart from the other points I mentioned.
foTONICS
Sep 30, 2011
332
I made the changes and it works now. Thanks for the help!
