network/computer switchable DC power
There are network switchable AC power strips available with HTTP and/or SNMP
interfaces that can be used to control the power on and off. But what I am
looking for is something that can do the same for DC up to 60 watts, with a
voltage range up to 24 volts and a current range up to 8 amps. The protocol
to control it can be anything that I would be able to manage from a computer
running my software. For example a serial protocol that used a "message"
that identified which power port and what state to switch to would work.
This device doesn't actually need to provide the power; just switch it.
Since many of the devices work with a variety of different power voltages,
it would be better to just use the device's original wall wart and cut the
cord to put the switching in line. Being able to control several power
connections on one device or board would be preferred. Anyone ever heard
of such a thing? Solid state preferred, but mechanical relay might be
considered. A computer I will be programming can be in proximity of the
devices, so direct connection (e.g. serial port) is an option. If it uses
its own PCI board for control access, it must have open source Linux drivers.
Control via individual parallel port lines (line up for on and down for off)
is _not_ an option (due to PC BIOS jiggling these lines during reboots).
Palindrome
The parallel port solution is the most obvious - but not a simple
connection to it.
Simply send two words out of the parallel port, in sequence. The first
is an "address code". That gets latched into a comparator and only if
it matches the set 8 bit word is the latched output port read-enabled.
If the address code sent as the first word matches, the second word is
latched into the output port.
If you are happy with 7 lines, you can use one bit to uniquely identify
that the word is a control word. That way, if a reboot/crash does happen
between sending the first and second words, the electronics will
recognise that the control word is set and disable the data port write
cycle.
Of course you could do all this with discrete logic chips. But a PIC
will be far, far easier and cheaper.
An alternative, again easier with a PIC, is to connect up a UART to the
serial port and write its output word to the output port latch. Easy
enough to do.
Another alternative if you want a LAN or remote facility, is to use a
very inexpensive cheap print server, either serial or parallel. Then
connect that to the PIC. Simply print a text file in raw data mode and
having solected a vanilla ASCII printer. Arrange a preamble in the text
file, that will be identified by the PIC as preceding the data, then
output a character with the appropriate ASCII code.
Another alternative is to get a USB /parallel/serial output unit from
the likes of Maplin:
http://www.maplin.co.uk/Module.aspx?ModuleNo=42857&criteria=usb kit&doy=14m2
or Quasar:
http://www.quasarelectronics.com/electronic_controllers.htm
etc, etc, etc.
The Universe is your mollusc...
Ben Miller
SNMP
am
a
protocol
computer
drivers.
off)
Why not plug the wall warts into the interfaced AC power strip?
Ben Miller
| connection to it.
| cycle.
I'm not wanting to build anything complicated. This solution would only
be viable if there's a product to do it _and_ that product ensures that
the signals that the PC BIOS sends out absolutely never cause any switch
events.
Hmmm.
Requires their DLL (so I guess it won't run on Linux).
| or Quasar:
They definitely document the issue I see with parallel ports. But their
serial port box looks interesting.
|> and/or SNMP
|> what I am
|> with a
|> protocol
|> computer
|> "message"
|> work.
|> it.
|> voltages,
|> cut the
|> power
|> heard
|> be
|> the
|> it uses
|> drivers.
|> for off)
|> reboots).
|> | Phil Howard KA9WGN (ka9wgn.ham.org) / Do not send to the address
|> below |
|> | first name lower case at ipal.net /
|> [email protected] |
| Get contactors rated at least 10 A, 24 VDC, with 120VAC coil. Wire
| the coils to your HTTP / SNMP power strips and thereby control power
| to your DC loads.
That would be a last ditch solution as it would have so many wires and it
would also involve connecting with 120V.
|> SNMP
|> am
|> a
|> protocol
|> computer
|> drivers.
|> off)
That is what we have now. There are problems with some the cheaper wall
warts not providing steady startup power.
Palindrome
| connection to it.
| cycle.
events.
Hmmm.
This approach, using a print server, really does have a lot of
potential - used with the Quasar Serial driver unit, for example.
| or Quasar:
The serial one is just a simple PIC-based solution as I described.
Once I have serial port control, I don't need much else as the PC in
control will be in close proximity.
I found a bunch of boards at this site: http://www.controlanything.com/
Tomi Holger Engdahl
For doing all kinds of controllign using parallel port I have provided
instructions here
http://www.epanorama.net/circuits/parallel_output.html
Just wire a suitable numebr of relays to parallel port, and use
the relay contacts to drive the DC loads you need to control.
There are many serial port or USB controllable I/O devices.
Use those to drive a set of relays that conrol your load.
John G
instructions here
Far too much junk comes with the above link.
Who wants to be the 99999999th visitor and win a handfull of blinking
ads?
| [email protected] writes:
| instructions here
No info on how to deal with the issue of the PC BIOS jiggling the state
of the parallel port lines if the PC reboots (I don't want a reboot of
the PC to reset the controlled devices).
I found them with the relays included (some to as much as 20A 250V AC).
Palindrome
| instructions here
There are many solutions:
1) Put an RC network on the data lines from the parallel port, so that
the input has to be sustained, say for 2 seconds, before a relay will
energise. The relays will not respond to the short transients during reboot.
2) Use the 8th relay N/C contacts to provide power to the other 7 relay
circuits. Ensure that this bit is low under normal circumstances. As
this line will go high during the reboot, it will prevent any other
relay from closing. You will need to put a few mSec RC network on the 7
data lines, to ensure that the 8th relay always operates first. You will
only be able to control 7 devices.
3) etc..
|> | instructions here
I don't want my intended signals delayed like that.
I think serial port is going to be more reliable. That and there are
products available for it that are not too expensive.
Palindrome
|> | instructions here
I addressed the implied question, "No info on how to deal with the issue
of the PC BIOS jiggling the state of the parallel port lines if the PC
reboots (I don't want a reboot of the PC to reset the controlled devices)."
The serial solution is more complex and uses more components - although
much of that complexity is hidden within the PIC. You are reliant on the
author of this embedded software getting it correct and bug-free. The
parallel solution does not use a bespoke component, such as a PIC, and
isn't reliant on third party developed software over which you have no
visibility and no control. So, the parallel solution is intrinsically
more reliable.
The two solutions will behave differently in the event of the computer
failing. The serial solution will normally retain the last set state,
indefinately. The parallel soultion will normally default to all relays
off. If this is important, you may have to allow for it by modifying the
design.
| more reliable.
In a hardware perspective, yes. But the PC parallel printer port is not
usable for that purpose. Some other kind of parallel port device is what
is needed to make effective use ... something the BIOS knows nothing of.
| design.
The parallel method will need some tri-state output ... a way to set OFF,
a way to set ON, and a way to just make no change.
