Neutral , ground & earth
electrosimonics
Feb 23, 2006
6
Hello everyone ,
                I just wanna know the difference between ( neutral , ground & earth ) nodes . So if any1 know the difference plz tell me . Thx a lot .
mvs sarma
Feb 12, 2006
234
Hi electrosimonics
to best of what i could recollect
NEUTRAL is used for public mains supply, either single phase (Live & neutral) or three phase Star connection ,4th wire being neutral. the concerned electrical supply companies general connect the neutral to ground at the point of thier distribution stepdown Transformer' output. It need not essentially be at earth potential by the time it reaches the user premises, but will be near to ground
Ground and earth are similar words-- i saw the term ground being used in American documentation especially.
sarma
MP1
Dec 7, 2003
3,397
"Ground" and "Earth" are actually two different things, but can be at the same potential. In other words, the ground of your circuit does not have to be connected to earth ground, which is the potential of the return or ground of the mains in your service box on the house. This is always at Earth Ground because it is connected to a rod that is driven into the ground. There are many situations where your chassis ground or case ground on the instrument would not be at the same potential as earth. There are also instances where you want a different supply ground or circuit ground than the earth ground or the chassis ground. Thus terms such as chassis ground and common come into play. When these potentials are different, the schematic will use different symbols to denote zero volts, common, analog ground, digital ground, chassis ground, and earth ground. Using different symbols to sort these out keeps this from getting too confusing.
MP
The Master1
Jan 17, 2006
17
Hi Folks,
is VERY deadly and once touched accidently it can at the very least make you break-dance from the shock or at the other end of the spectrum , it can kill you "stone dead" instantly.
I have a page specifically directed at mains voltages, 240 Volts AC to be exact, which here in Australia​
