New Soldering Station? XYTronics LF855-D
rudedog9d
Oct 10, 2012
So I had a Weller Heat a Print, which apparently had support ended for it in the early 90's, so when my tip crapped the bed I figured it was just time to upgrade. I've Looked at some different stuff, and I wondered what some others might think about a LF855-D?I do a wide variety of Electronics repair, usually relatively small stuff. I'm in high school so I only have a few hundred to spend on a new system, and that's also why I don't really have a specialty.
So, That's my story and what I found. If any one has ever tried one of those, or if you have other suggestions, I'm open to Ideas! Some links to the LF 855-d System Below.
http://www.xytronic-usa.com/shop/item.aspx?itemid=27
http://www.jameco.com/1/1/5457-lf-8...ti-function-surface-mount-rework-station.html
http://www.jameco.com/Jameco/Products/ProdDS/2144577.pdf
https://www.howardelectronics.com/xytronic/Images/LLF-855D.jpg
Thanks alot!
-Brodie
CocaCola
Apr 7, 2012
3,635
No opinion on the one you have linked...
But, even though you find a lot of 'negative' stigma attached to the China imports on the Internet, I will continue to FIRMLY stand behind them as a damn good $ for $ alternative to the name brands... I have been using them full time for years and have had VERY little to no issues at all, they simply work and continue to work year after year...
I don't have the exact dates off the top of my head but give or take in the last 12-14 years I have burned out only one heating element in one station, that is the only fault I have had besides your normal tip replacement schedule... The new replacement wand (to lazy to tinker with a heating element swap for the price) for that station cost a whopping $12 to replace and it still functions to this day... And it's not uncommon for me to have the station(s) on for 12+ hours a day...
If you are one of the guys that has to have Snap-On tools because Stanley isn't 'shinny' enough, the cheap import stations are probably not for you, but if you want a lot of bang for you buck, don't dismiss them...
The ones I use are the house branded 'CSI' one from Circuit Specialist...
This regular station...
http://www.circuitspecialists.com/csi-station1a.html
And this rework station to be exact...
http://www.circuitspecialists.com/csi906.html
If nothing else have a look around their site at what they offer in 'cheaper' alternatives to the big names...
http://www.circuitspecialists.com/soldering-equipment
