newb: I'm trying, but need this cleared up...
SklettTheNewb
I have been messing with CircuiMaker and doing "spice simulations"
I have also been reading from these different sites:
http://www.kpsec.freeuk.com/ohmslaw.htm
http://www.play-hookey.com/digital/ripple_counter.html
http://www.allaboutcircuits.com/vol_1/chpt_2/index.html
I'm slowly getting my head around the current and voltage ideas. I
have encountered a strange situation w/ a spice simulation like this:
LED 680
..--|<-----|___|-----.
| |9V
(created by AACircuit v1.28.5 beta 02/06/05 www.tech-chat.de)
if I place the probe before the 680 ohm resistor, I get 9v, if I place
it between the resistor and the LED I get 1.79V and 10.60mA
I'm trying to understand how I got that number, I know that;
V
I = -
if I use that formula with my values:
9
- = 0.013
680
- that makes no sense.
I'm missing something VERY basic and simple, but I can't figure it out.
Any help or guidance would be REALLY appreciated at this point.
Steve
Andrew Holme
LED 680
V
I = -
9
- = 0.013
680
out.
The voltage drop across the resistor is 9 - 1.79 = 7.21 V
7.21 / 680 = 10.60mA
F
Fritz Schlunder
LED 680
| |9V
V
I = -
9
- = 0.013
680
LEDs aren't resistors and don't obey Ohm's law. They usually have an
approximately fixed voltage drop across them almost independent of the
current flowing through them. Your simulated LED has a forward voltage of
1.79 Volts. This is a fairly typical voltage drop for most LEDs except for
blue and white ones (which usually drop closer to around 3.5V)
You have a voltage loop. The sum of the voltages around the loop (if you
respect polarities) is always zero. Starting from the bottom of your
schematic and going counterclockwise you gain +9V up through the voltage
source, then you drop 7.21V across the 680 ohm resistor, and then drop
another 1.79V across the LED. So +9V - 7.21V - 1.79V = 0V. If in your
simulation you were to measure the voltage across the 680 ohm resistor
(instead of just measuring voltages with respect to ground) you would indeed
find it to be 7.21V. The resistor obeys ohms law and you will indeed find
that yes: 7.21V/680 = 0.01060A.
Bob Eldred
LED 680
| |9V
V
I = -
9
- = 0.013
680
Steve
Your equation is right but your reasoning is wrong. You measured the voltage
across the LED as 1.79 Volts. What is the voltage across the resistor? Well,
it has to be 9 - 1.79 = 7.21 Volts, right? Therefore the current is I = V/R
= 7.21/680 = 10.6 mA. As you can see, ohms law applies to the voltage across
the resistance in question and not some other voltage like the battery,
etc. Now, given that, what is the resistance of the LED? You should get
168.8 Ohms. What is the series resistance of the resistor and the LED, You
should get 848.8 Ohms. Now what is the current in the circuit, It should be
(total voltage/total resistance) 9V/848.9 = 10.6 mA which checks.
SklettTheNewb
Great answeres all, I was missing the "voltage across the component"
part, I was trying to base everything off of the supply voltage.
This makes sense now, thank you for the great responses.
Take it easy,
Steve
Active8
Argghh! I just looked at that third link. That current convention
thing (from menu on the left) is backwards to anything I've ever
seen in circuit analysis texts and will f you up if you pusue
electronics seriously - like Kirschoff's laws and node and mesh
(loop) analysis.
It's this way:
+ V -
___
-|___|-
I -------->
Note that this is the same from the perspective of voltage
generators as opposed to drops. An example might clear this up:
+ | ^ I |
V - | | | | V
- | | V |
| I |
^ call this the reference node or O V
Kirschoff's Voltage Law (KVL) says that the sum of the voltage drops
around a closed loop equals zero.
Sum(V_i) = 0. or
n
___
/__ V_i = 0
i=1
Starting at the negative terminal of the batt, and noting that we're
going with the flow, i.e., current (charge flow), from negative to
positive, we have a negative drop or positive voltage rise. Say the
drop is -9V, i.e. 0 - 9 = -9 You take the starting value and
subtract the ending value.
At the resistor, we're going from positive to negative, which is a
positive drop from 9V to 0v, i.e., 9 - 0 = 9
so -9 + 9 = 0
Another way of stating KVL is that the sum of the generator voltages
is equal to the sum of the voltage drops. So in the same manner,
going from the reference node to the positive terminal of the
battery, we have a positive generator and
9 = 9 which is the same as 9 - 9 = 0 or -9 + 9 = 0
I'd recommend a better site if I knew of one for sure. Maybe that's
the only thing wrong, though.
Active8
LED 680
| |9V
V
I = -
9
- = 0.013
680
Yes. You're missing the fact that the voltage across the resistor is
9 - Vf or 9 - Vd, the drop across the diode, V_d, or its forward
voltage, V_f. Plug that in. Hint: V_f is 1.79 V since you're
measuring it relative to 0 V AKA "common" sometimes AKA ground AKA
GND.
I might as well mention that in this group you'll be seeing
notations like Vf and V_f which just means that "f" is a subscript.
We try to do what it takes to get the point across. Look at some
data sheets and parts catalogs.
Colin Dawson
LED 680
| |9V
V
I = -
9
- = 0.013
680
Steve
Maybe I can help a little. I'm using Livewire, to simulate the circuit.
Let's add a few points to the circuit to help make things a little easier to
explain...
Probe B Probe A
LED | 680 |
| |9V
Probe C
The current for this circuit is 10.44mA.
The Voltate at the power source is 9v exactly (as I'm using a circuit
simulation this won't change unlike real life, but let not complicate things
with that)
The measured voltages are as follows
Probe A is 9V
Probe B is 1.9V
Probe C is 0V
The difference in voltage between Probe A and Probe B is 7.1V Remember
there's still 1.9V left to drive the LED
So from that
9V/680R = 0.01044A
This is in Amps. My Simulation shows the current in Milliamps so I need to
multiply my figure by 1000
0.01044A*1000 = 10.44mA
So what's the resistance for the LED?
V/I=R
The measured voltage for the LED is 1.9V (Probe B) so
1.9V/0.01044A = 181.992R (182R will suffice)
Add that to the 680R and lets do the entire circuit.
9V/(680R+182R) = 9V/862R
= 0.01044A
= 10.44mA
I hope this helps a little.
Regards
Colin Dawson
www.cjdawson.com
