Chris-Wilson
- Jun 23, 2006
- 9
- Joined
- Jun 23, 2006
- Messages
- 9
Ok, I know this is a newb question, but i have tried everything. So, I have a 12 volt, 80 milliamp relay coil connected to the emmiter of a transistor (TIP3055), the base input voltage of .7 volts, and the collector leading to ground. To protect the transistor, I have a diode (Rectifier: diode [2.5 amps 1,000v]) between the resistor coil. Previously, with a different transistor (one I scrapped from an RC Car) it just locked in the on state, where as with the current one mentioned above, it doesn't switch at all. ??? Someone please enlighten me! I altered the schematic, replacing the 5 volt relay with a 12 volt from "http://www.rentron.com/Files/TWSAKIT.pdf"
Thanks.
Thanks.
