Newbe Help with this schematic
stspringer
May 10, 2019
116
Hello All,
Newbie here.
I am not clear on this schematic, on how the touch metal, hooks up. Is it just 1 wire going from the 100k resistor to the touch metal? Please advise.
Thank You
stspringer
14,317
Your body works as an antenna. The tiny signal is fed to the base of the transistor Q1. As there are 3 amplifying stages, a very small base current sufices.
The 100 kΩ on the other hand protects the transistor from high currents in case of e.g. an ESD discharge.
stspringer
May 10, 2019
116
Thank you, very nice
stspringer
May 10, 2019
116
I just tried it with metal and my finger and it doesn't work. It only works if I jump the gate and the collector of Q1
14,317
The "gate " is called base in a bipolar transistor and yes, of course it works then because the base gets a positive current from R1 and R2.
Did you try barefooted? I'm not joking.Standing on well isolated soles may reduce the amount of noise available below the required minimum.
A more sophisticated single contact sensor is shown e.g. here.
A more reliable method would use a sensor with 2 plates which have to be touched (bridges) by a finger. You can use the circuit you found and add a second plate which is connected to +9V. Or use this even more simple circuit.
Minder
Apr 24, 2015
3,561
Would Mosfets work better? They operate on almost zero current and relay on voltage to switch.
The 2n7000 is cheap.
Maybe clamp the gate with a zener.
M.
stspringer
May 10, 2019
116
Thanks I will check out your sites. Thank you
stspringer
May 10, 2019
116
M.
I am a newbie don't forget :) you are speaking greek to me.
Nah...He's from Canada so more likely "French". o_O
You might want to take a peek at Talking electronics web page.
It has many such circuits and a host of other projects good for beginners as well as others.
Books, circuits, explanations...all good.
For your present project scroll down the left side to "touch switch"
Edit:- just take note that they show some circuits which do not work and the reasoning behind why.
Cheers Jorgo
http://www.talkingelectronics.com/te_interactive_index.html
