newbie question
leedude
Feb 13, 2007
20
hi, i have just started with electronics, and i was wondering, is there a component out there that would sort of strip off power from a power supply to give a 5v output, as the power supply dropped from 12v?
is this called a zener diode or something?
ante1
Jan 24, 2004
4,136
A zener diode might work for low currents and low stability requirements but an LM7805 (there are many others too) will supply more current and high stability!
leedude
Feb 13, 2007
20
hmm..ok, i have refined the concept a little,
i need the power supply to accomodate an lcd(consumes about 250ma). The input must be a 9v battery, and it must produce an output of 5v. what should i use to build this supply? could i use this: http://www.maplin.co.uk/module.aspx?detail=full&ModuleNo=46321&doy=20m2#more_info
if so, what caps/other components do i use with it? a circuit diagram would be nice.
audioguru2
Apr 6, 2004
12,022
What kind of LCD display consumes 250ma? It must have a very bright light in it.
A little 9V alkaline battery can supply 250mA for only a short amount of time. The low dropout 5V regulator will work fine for a little more than one hour.
The circuit diagram for the low dropout 5V regulator is in its datasheet that is in your Maplin link. Use two tantalum capacitors as shown.
ante1
Jan 24, 2004
4,136
You must mean 250uA which is more realistic!
