realexander
- Jan 1, 1970
- 0
I'm having trouble getting a transistor to work the way I thought it
should, and I hope someone could help me.
I'm using a PIC to drive common anode 14-segment LEDs. Since the PIC
I/O line can't supply enough current, I'm trying to use a 2N2222
transistor instead. The PIC directly drives the 2N2222's base (no
intervening resistor), the collector is tied to +5 and the emitter to
the common anode. The problem is that, while the LEDs light, they are
very, very dim - only visible in a dark room.
I thought maybe that the PIC wasn't saturating the transistor, so I put
in a pull-up resistor on the base. No difference. I connected the base
directly to +5, and the LEDs were still dim. The emitter shows +4V (5
volts in the collector, 4 volts out the emitter??!!) If I tie the LEDs
common anode to +5, they light up nicely, but of course I can't
multiplex a bunch of LEDs with the anodes tied to +5.
Am I using an inappropriate transistor? Am I using it wrong?
Bob Alexander
Bob Alexander
