Newest Toy
Glenn Gundlach
Jim said:
On Mon, 17 Jul 2006 15:21:07 -0400, Chuck Harris
Yep. It's been 26 years since I added a room to the old house and
hung drywall... my office. And I cheated... rented a special sprayer
to put down "orange peel" ;-)
...Jim Thompson
1: neat tool. I assume its similar to using a router in that guides are
helpful for straight lines.
2: Opti-visor (like mine)
3: good camera. What is it?
4: Sorry to hear about your son. My condolences.
GG
Richard Henry
Chuck said:
They are called Roto-zip tools, and they are nothing short of fantastic,
for what they were intended to do. Somewhere, someplace, they got the
idea to hang everything, including the kitchen sink off of the tool, and
sell them to harry homeowner. I think that was a dangerous mistake.
With the proper bit, they will cut most anything, but they are more than
a little bit wild. They will core you if your aren't careful. The bits
will break in a blink when they get dull, or if you force them.
Using them with fly cutters, and router bits is an accident waiting to
happen, yet they are encouraging just that kind of use.
When they built the new high school where I grew up, a wood and auto
shop were included. Within a few months, two fingers were missing from
students (two _separate_ incidents of trying to clean shavings from the
planer as it spun down) and three from the shop instructor (table saw).
After the instructor spray-painted the large tools using his
abbreviated hand as a stencil the carnage stopped.
Later, a friend of mine removed one of his fingernails with a router.
Stephen Rush
A fly cutter in a high-speed handheld tool??? That would take the kind of
doofus who searches for gas leaks with a candle. I can see using a small
router bit, if you have the router base.
Jim Thompson
When my oldest son was at Chaparral High School (North Scottsdale) a
kid lost 3 fingers on a band saw and they were vacuumed up by the
central shop vac.
While the medics were stabilizing the kid, my son dumped the saw dust
out on the floor and recovered the fingers.
They were successfully reattached!
("Course it helped that the kid's father was a surgeon ;-)
...Jim Thompson
Jim Thompson
Yep, though I cut these receptacle holes freehand. That's why cover
plates are larger than electrical boxes ;-)
I bought mine (IIRC) around 1980... love it!
An old Sony Cyber-Shot 3.3 MegaPixels, DSC-S70, "macro" focus setting.
GG
Thanks!
...Jim Thompson
Joel Kolstad
Ouch! I remember being annoyed that the machine shop I visited while working
in college required you to wear jeans and a long sleeve shirt, even if it was
100 degrees out... maybe they were onto something there...
I never did take issue with using a push stick whenever you were getting close
to finishing the cut through your material on a band or table saw...
Jim Thompson
I saw this website which was interesting, though I am not sure that I would
buy one, unless the false-alarm rate is practically zero it could get
pretty expensive.
www.sawstop.com
Although I think it is a nice piece of brute force engineering, I think they
spend too much time going on about how much you will get sued for if you
don't buy their thing. The videos are pretty big downloads also.
Chris
Pretty impressive!
...Jim Thompson
Chris Jones
pretty expensive.
www.sawstop.com
Chris
Rich Grise
I'm thinking an exceedingly hard, sharp, tough bit, (case-hardened
carbide?) running at insane speeds, could dig through tile, but
yes, I'd want some substantial safety glasses for when it snaps. =:-O
Thanks!
Rich
Rich Grise
I learned all that crap at the age of about 8, because Dad inherited
Grandpa's ShopSmith.
I came home from school one day (about 5th grade or so) to find that my
brother (about 10th grade) had cut his finger on the table saw and was
on the way to the hospital.
They saved the finger. :)
Cheers!
Rich
Chuck Harris
For tile, the sell a solid tungsten carbide 1/4 inch diamond cut router
bit. It walks right through normal clay based tile, such as is typically
seen in bathrooms (eg. 4 inch square clay bisque tile). It would have a
problem with porcelain floor tile, as it is much harder, but it would still
cut it...slowly. You have to let these bits cut at their own rate. Forcing
them is a recipe for instant destruction of the bit.
-Chuck
Joel Kolstad
they
They're competing in an old, mature commodirty market with pretty small
margin, so it's pretty hard to convince people to buy new shop equipment
unless you can convince them of a significant benefit -- not getting sued
for millions of dollars is perhaps the only thing many shop owners would
listen to!
Agreed, they should have a "dial up" option.
---Joel
Mark Harriss
Forcing > them is a recipe for instant destruction
of the bit.
-Chuck
They use diamond router bits for edging granite, once saw
a guy using one with a garden hose to supply cooling and
lubrication. Also seen a guy successfully route the edges
on a 4 inch thick aluminium slab with a handheld router:
very, very slowly and with lots of lubrication.
Chuck Harris
Hi Mark,
Not quite the same thing. The router bit I was talking about
is solid tungsten carbide, and is cut with diamond shaped
facets. It is sort of like a round version of a bastard cut
file.
The granite guy was certainly using a diamond abrasive cutting
tool. Granite eats tools for breakfast.
Routers have a tendency to self feed, and when they take a big bite,
they want to take another, and another, and pretty soon, they have
jerked their way out of your hands. They are best used with soft
materials, and using tools that can only take a very small bite with
each revolution.
-Chuck
Aristotle Eisenglas
Jim Thompson said:
Pretty impressive!
...Jim Thompson
| James E.Thompson, P.E. | mens |
| Analog Innovations, Inc. | et |
| Analog/Mixed-Signal ASIC's and Discrete Systems | manus |
| Phoenix, Arizona Voice:(480)460-2350 | |
| E-mail Address at Website Fax:(480)460-2142 | Brass Rat |
I can't exactly remember. IIRC they rattled a little bit ago.
Joe Huge proctical problem: the entropy source thay are
discussing is available to guests (without login) at a few
datasheets I don't see a problem. Also some solenoids used on
AC will actually get HOTTER if the plunger doesnt pull in.
The bit that happens to me, I usually rely on Rosy and her five
lovely daughters.. ;-) Cheers! Rich peak inverse voltage.
forgot to mention. (Used those nice TEK ceramic strips from the
old 500 series,too bad they aren't made any more,they were handy
for dummy loads.) Yes.
I'm just being a troll's advocate. (Personally, I think guns
should only be permitted to trained members of the cat family.
in mating season or protecting their young can be equally
dangerous - ie deer or moose. I'm sure there are atleast a
million ways to make the modulation so small that the system you
are running is not trusted, i.e. some malware (rootkits,
keyloggers, etc) is running on the test bench. [SHAMELESS PLUG]
DaqGen is the signal generator portion of the UVA spectrum
(roughly 315-340 or 315-330 nm) is fairly well blocked and UVB
and shorter wavelength UV are . <SNIP> - Don Klipstein () Do you
run red light just because you feel like sharing the SM - you
could post the contents list and authors? The Descent got a UK
release last year and it was pretty good.
