They certainly won't be bright at only 0.5mA! 20mA is usually used.xtp said:Bright white LEDs must be supplied with min. 2.9V (@about 0.5mA ;D)
Good, then you can use tiny 850mA/hr AAA Ni-MH cells. They are much smaller and lighter than AA Ni-Cad cells. ;Dxtp said:But if the circuit is used only six hours a day then the batteries will have to be recharged only after a week ;D.
The step up circuit should be simple and compact, so the lamp will easily fit in a pocket.
A metal crystal has probably grown accros the electrodes, you could possibly revive them by giving them a few >10A 1 second pulses to vapourise the crystal.audioguru said:Most of my old Ni-Cads leaked or shorted so I've been using Ni-MH cells instead for a few years.
About double if I remember correctly, but this and their non toxicity are a the only advantages NiMH cells have.The capacity of Ni-MH cells is much higher than Ni-Cads.
[The difference is they use the industrial grade batteries which have better seals and have more ruggedized construction to take on more abuse.
I have a lot of new NiCd batteries and I plan to use them.audioguru said:Good, then you can use tiny 850mA/hr AAA Ni-MH cells.
You don't need a complicated charger unless you leave them charging for weeks, or need fast-charging.xtp said:I have a lot of new NiCd batteries and I plan to use them.
NiMH batteries are smaller ;D, but they require a more complicated chargerthan the NiCd batteries.
