Non Electrical Engineering asking for possible solutions to a problem
Leo Violette
I'm writing software to track billiard balls on a pool table. I need an
accurate way to track the balls. Each ball would have to be uniquely
identified. I've thought about using a video camera, but it would require a
high ceiling to be overhead or some complex calculations if it is at an
angle, then there is the issue of writing recognition code to find the
balls. I suspect it wouldn't be the most accurrate or the fastest solution
in the world.
Is anyone aware if it is technically possible to implant a tiny non-powered
(or battery powered if it lasts a long time) chip into each ball? Then,
perhaps through some sort of triangulation method, the location of each ball
could be communicated to within an inch or so of their location. If this
information could be communicated several times a second too, that would be
most ideal. Then, perhaps with the devices that do the triangulation, I
could figure out some way to send that data to a pc running software that
could provide this information. I'm a software engineer, so my limitation
is in trying to imagine the hardware aspects of what I'm trying to do.
Is this something that can be done? I'm not entirely sure what billiard
balls are made of, but I could find out (if that might impede a signal). I
believe they are made of some sort of hard plastic.
Any thoughts would be greatly appreciated!
Leo
temp9baller at comcast dot net
alt.engineering.electrical
Garrett Mace
in the world.
Leo
Honestly a vision system is a good solution. What more could you ask for:
you've got a continuous-color green backdrop to do object detection, all the
balls are different colors or have a highly-visible white stripe. No need to
try modifying the balls.
Other solutions require a highly modified table and ball set; maybe if you
had a pressure-sensitive matrix under the padding, you could track the
location of each ball in realtime if your system was fast enough. There are
a lot of quick motions on a pool table, but you're helped by the fact that
no two pressure points can be closer than the diameter of a pool ball. Pool
balls are decently weighty too. Radio-triangulating would be exceptionally
difficult at that distance and with so many points, also complicated by the
fact that the balls will be spinning along and changing the signal strength
as the antenna rotates. Some kind of radio-detection grid under the table
would be pretty intensive and also difficult to get any good resolution out
of.
C What I Mean
"> > I'm writing software to track billiard balls on a pool table. I need
an
require
Vision might be the easiest but there may be a couple of problems to
overcome. Consider that if the stripes wind up horizontal, they would look
just like the solid colored balls from the top If the balls were striped
with two striped that are perpendicular to each other. That may help.
Also, you would have to of course use green felt and not blue.
Could be done.
Leo Violette
That is one of the problems I had considered too. There are others, like
when all the balls are in the rack, it might be hard to tell where one ball
ends and another begins. Plus a ball or several balls could be in a pocket,
I'd have to code for where the pockets are so I don't look for balls there
and think they are on the table. There is also the problem of the shooter
and the cue stick being on the table interfering with the recognition
system. The camera would have to be solidly mounted and any slight
movements might mean a recalibration in the software of where the pool table
is (of course, unless I can just scan and find it myself). I'd need to be
able to find the edges of the playing surface which can be difficult since
the felt rides a couple inches up the rail.
I'm hoping this uses a sort of standardized system so that one person can
build a database of shots that he makes and his percentage of making them.
His next door neighbor can also do the same on his table and the coordinates
work out the same. I'd have to adjust for how big the table is in the video
and do some calculations to compensate for different zooms if my software
knows how big the table is physically.
Ultimately, what I want to see/sell is a service to people like ESPN2 (who
occasionally show billiards on TV) to make pool more TV friendly. You never
watch a baseball game without getting all sorts of percentages. If there
was a player shooting a game winning shot, it would be nice if the
announcers could say how often he has shot it in the past and how often he
made it. Also, something that would make pool more TV friendly is if I
could communicate how hard (speed of the cue ball) the shooter hit the break
shot with. It's those little things that I think would make pool more TV
friendly and entertaining for people to watch. Plus, people at home could
setup the same shots and try things themselves and measure their break speed
too.
The speed things (tracking a cue ball during a shot) is why I needed several
iterations per second. Of course, a video camera will easily do between 24
and 30fps. I suspect that would be perfect for my purposes. However, I
doubt I will be able to perform the analysis of the data in real-time.
There will have to be some delay. That is just a side-effect of me having
to look for the balls rather than having a system where the location of the
balls are communicated to me.
Leo.
Leo Violette
See comments inline...
Marc Reinig said:
There are numerous solutions: Visual will be the cheapest, Software can
compensate for the angle of the camera if it is not dead center above, but
looking from aside. The calculatrions are not all that complex,
particularly compared to the complexety of the entire task, which is not
necessarily that complex.
The angle will not be the only issue, but also the level of zoom (how much
of the total viewer screen is the table taking up). If I don't, then ball
coordinates couldn't be "universal". In other words, you and your neighbor
both have the same setup, but he is zoomed a little closer to the table.
Unless I compensate for that (which I plan to do since I will know the
physical size of the table), our coordinates wouldn't match and we couldn't
setup each others shots on our own tables.
How fast do you need to know all the positions? Real time or analysis after
a shot. i.e. that data can be collected real time and analyzed real time or
analyzed after the fact. The first is necessary for intercepting things,
the later is fine for post mortem analysis.
I suppose analysis can be postponed. I'm wanting to be able to communicate
how hard someone hit a shot (like the break shot for instance). Maybe I
would communicate that the break shot was hit at 24mph or 18 feet/s. Who
knows, but that sort of thing would make pool a bit more TV friendly.
**THE-RFI-EMI-GUY**
You might want to look into RFID chip technology. These are devices used
in ignition keys for anti-theft protection in Ford's and also implanted
in pets to aid in recovery. They are powered from a coil nearby which
transponds a unique ID code. In your case, the billiard table would
require an X-Y grid of wire loops to determine where the ball traverses.
The key question would be how fast, the system would need to be to
accomplish what you are trying to accomplish.
Leo Violette
Thanks for the links Guy. I'll take a look at them and see what I can find.
aceji
One of the kids at my lab last summer implemented something very similar (he
built an automated fooseball table with a 60 dollar webcam.
He used the webcam to capture the table and then wrote a c-script to track
the balls via color. His project was limited by the fps of the camera, but
the computer processor accomodated for delay errors by the camera.
I think for the sole purpose of tracking billiard balls this will work,
Ji Zhang
