noob question,easy answer
turbogt16v
Mar 27, 2015
176
Hy i just bought DC DC Converter Step Up Boost Module 3V To 5V 1A USB Charger For MP3 MP4 Phoneusb charger.
specs are
Module Properties: non-isolated step-up module (BOOST)
input voltage: 2.5-6V
Output voltage: 4-12 V(Adjustable, the default 5 v)
Output Current: the maximum 1000mA
Efficiency: Up to 92% (the higher the input voltage, the higher the efficiency)
Switching frequency: 1MHz
Output ripple: 20mV (MAX)
Operating Temperature: Industrial (-40°c to +85°c)
Voltage regulation: ± 2.5%
so my question is when i power some device with correct voltage but weigher amperage what would happen.
if i power this device with 5v 3a would it burn
14,486
The device will only draw the current it needs
you can put a device requiring 1 amp on a 20 amp power supply if you wish
always ensure the voltage is the correct one
14,486
its an extremely common question on many forums
usually because those asking the question haven't got around to learning the basics
do some google searching on Ohms Law and how it relates to resistance, current and voltage :)
