Norton Resistance question
Phil Allison
Can someone tell me (step by step) how to calculate the Norton's
resistance for this circuit? (see picture below)
http://www.progressivetel.com/~radney4/NT.jpg
** Using Norton here is silly and time wasting.
It is simply a parallel resistor problem.
1. RL plus R3 parallel R 5 - so compute the combined value.
2. This value plus R2 parallel R4 - so compute the value.
3. Add this to R1.
....... Phil
Jasen Betts
treat the voltage source as a short circuit (or as a fixed resistor if
it has non-zero resistance) and solve for the resitance at the part that
interests you (this would be the output terminals)
neon
Oct 21, 2006
1,325
Try thevenin that is a snap. look up thevenin theory.
W
whit3rd
It's not clear from the OP's problem statement that RL should
be included in the Norton resistance, or just the network up
to RL leaving a Norton equivalent driving the load.
Exactly so. Norton's theorem applies to a two-terminal device
consisting of voltage sources and resistors. Tell us _which_ two
terminals of the seven, or there isn't any soluble problem presented.
