Not enough current to trigger relay.
Minder
Apr 24, 2015
3,561
Only disappears for me when I log off and read the posts?o_O
M.
Tha fios agaibh
Aug 11, 2014
2,253
I managed to find a 12vdc source that was used to run the buzzer. I thought that this was perfect, I would just use a 12V relay to act as a switch for a 24vdc source that I have available and the horn would sound when the phone is ringing - easy. The problem is that the 12Vdc source inside the phone lacks the current
How about a 12v reed relay? The coil current is only about 12ma and the contacts should easily handle your horn.
Tha fios agaibh
Aug 11, 2014
2,253
did you not see the flag where I pointed the lower arrow ?
don't you see the flags for other members as well like mine ??
I see your flag for the USA
Yes, but does not show on my screen.
No, I can't see anybody's flags.
Perhaps I need to update java script?
All I see is; member name, status, and Avatar.
14,470
possibly ? I don't know if its a java controlled thing or not, only Ian may be able to answer that
try installing it and see if it helps ... you should be using java anyway ... may things that it is used for on www sites
are you on a phone ? do you never log in on a computer ?
14,470
Yes, I'm on an android.
I'm seldom on a home computer.
ahhh that probably explains it ;)
I don't log on to the forum from my phone too often, so cant remember what is and isn't shown
no probs ... just one of the benefits of full access via a computer :)
Tha fios agaibh
Aug 11, 2014
2,253
Yes, true.
Everything else works fine on my phone.
Anyway, I hope you'll excuse my asking where a member is located, from time to time.
PS: It also doesn't show under their profile.
14,470
no probs, buddy, now we know the limitations ;)
yeah, just fired up my HTC Android phone, agree
on a PC, in a thread, you get to see their join date, how many messages send and country
under their avatar
wonder if the iPhone is the same ?
KTW
Feb 22, 2015
273
Those horns were controlled through a separate 24volt power supply.
