Not Working on Proteus ISIS
aayush_vetwal
Jun 30, 2013
Why doesn't the motor in this circuit run in Proteus ISIS?
duke37
Jan 9, 2011
5,364
Perhaps the aerial is not picking up sufficient signal.
Seriously, the motor power and type of motor is needed.
What is the power supply.
The IC contains a triac which indicates it might be an AC supply driving an AC motor. The led will not like this at all.
Someone may be able to help if you can give some more information.
14,487
does the motor run if its directly across the PSU ?
you still haven't told us what voltage the PSU is ?
I assume you realise that this circuit doesn't do anything other than prove if the opto-coupler works or not ?
CDRIVE
May 8, 2012
4,960
ISIS has quite a few motor models. What's the model you're using and what's the value of V+?
Chris
