Joerg
- Jan 1, 1970
- 0
qrk said:Keep one solid ground plane.
Using a linear regulator on each channel is a good way to isolate
power supply cross talk, so, keep that in.
You will have more problems with that switcher getting into things.
The switcher needs to be properly laid out on the pcb or you will get
switching noise into places you don't want it. Linear Tech. has the
layout of their reference designs for most or all of their switchers.
If you can't find it on LT's web site, call your LT rep. LT has
excellent customer support for the small guy. It is a good idea to use
LT's layout as a reference. If you can, use one of the MHz plus
switchers, then, apply ferrite beads to input and output of the
switcher.
And by golly, use shielded inductors on those. Else you might sing the
blues at the EMC lab.
