Novice needs help with crazy project
MassiveProng
You are still infantile as ever.
Said the retarded **** that said I needed a brain?
Hypocrite!
Oh, well. Meanwhile, please check
with someone other than your dad about M80's
I lived in Cincinnati, right across the river from the Kentucky
plant that made them for the Army, you retarded ****.
and where their oxygen
comes from. You may learn something.
I am fully aware of how they are constructed, and why there IS
airspace in them.
Jon, the utter retard.
Yep... I concur.
Jack
Other than just pig-headed stubbornness, is there any reason why you
top-post?
I work in an environment where a very large amount of communication is done
via email between a very large number of people in a Fortune 500 company and
everyone top posts. It just seems right to us. I was not trying to be
difficult. I was only ignorant of your adamancy.
Jonathan Kirwan
<snip>
airspace in them.
<snip>
You still abundantly proved you know nothing about their chemistry to
everyone. You still are in serious need of almost any education.
Best of luck with your infantile insults, which are at least at a
level consistent with your science knowledge.
Jon
MassiveProng
This is NOT email, and you should use something OTHER than Outhouse
Express to read your news with, and post from.
Google "News Client".
MassiveProng
I would bet right now, fucktard, that you do not even know what is
in one. (the old, out of production REAL versions, not the SHIT out
there today).
Rich Grise
That's email.
This is USENET.
There's a significant difference. (several differences, actually.)
Try this:
http://dmoz.org/Computers/Usenet/Etiquette/
Good Luck!
Rich
Jonathan Kirwan
there today).
I'm glad you imagine you do. It doesn't change the fact that you
abundantly announced to everyone that you know almost nothing about
chemistry and are seriously in need of an education.
Jon
Y
YD
Late at night, by candle light, MassiveProng
One used to be able to make a "cable box" for "experimental
purposes".
They still may, but using it on the cable line is where the felony
theft of service comes in. Doesn't do much just sitting there without
a cable hooked to it.
If I EVER made a "one off" of someone else's patented product or
process, I would certainly be in correspondence with that person.
It is just plain good civil practice, and if you claim to be a
member of civil society, you should have enough presence of mind to
know the difference between an experiment and a rip off or avoidance
of paying one's dues.
Oh **** off. I'll do whatever I damn well please and there's nothing
you can do about it except piss and moan.
- YD.
BILKS
HEY MANG WAT U DO GIV ME HELP FO MY PROJET WAT IS A CAPCITOR
Mike_in_SD
[email protected] (MassiveProng) wrote in
Lazy fucktard. Get out of Usenet then you retarded ****.
Here is a quote (cut and paste actually) from the very page you guys
keep sending me to .. to see YOUR rules ..
read the last line of YOUR fucking bible ...
but I guess you decide which rules apply ...
quote:
If you are sending a reply to a message or a posting be sure you summarize
the original at the top of the message, or include just enough text of the
original to give a context. This will make sure readers understand when
they start to read your response. Since NetNews, especially, is
proliferated by distributing the postings from one host to another, it is
possible to see a response to a message before seeing the original. Giving
context helps everyone. But do not include the entire original!
so yes .. I understand the bottom post thing .. but .. if YOU are too
fucking LAZY to trim the post then put up with the top post. period
Don Klipstein
Hypocrite!
airspace in them.
Consider how much oxygen is consumed when they explode, compared to how
much oxygen is in that airspace:
M80s have something like 99% or more of their oxidation done by oxygen
in non-gaseous material that they have.
Don Klipstein
there today).
http://en.wikipedia.org/wiki/M-80_(explosive)
That article mentions use of "flash powder". A main ingredient of that
is an oxidizer that is usually a chlorate or a perchlorate of sodium or
potassium, although permanganate of potassium has been done and
permanganate of something else such as sodium is possible. Nitrates
are also cited as oxidizer. The fuel of "flash powder" is typically
powder of magnesium or aluminum, although I consider doable with a mixture
of these, also to lesser extent with titanium and other metals towards the
left end of the periodic table that do not excessively spontaneously
corrode when exposed to air (which largely excludes metals in the first
column and metals in the second column below magnesium, and Be is
impractical due to lower availability and higher toxicity of its main
oxide).
http://en.wikipedia.org/wiki/Flash_powder
Don Klipstein
I would like to add that "topping" is fairly common practice in e-mails
in industry.
In Usenet, the culture varies from this somewhat. So I advise that in
Usenet that top-posting only be done above maybe 12-15 lines or less of
quoted material or have adequate indication early-on of having
top-posting, reasonably obvious in first-page-view in all popular
and decade-back-popular newsreaders including dating back to "tin" and
"slrn".
Meanwhile, I do find that most of those who bitch the most about
top-posting tend to be grasping at straws to fight their way upward from
deservedly lower positions in whatever "pecking order" that they want to
ascend within.
jasen
Gurus,
I need your help...
I am an amateur triathlete and I'm getting ready for the start of the
triathlon season and I had this problem last year that I'm trying to
solve.
The problem is that during an open-water triathlon swim I need to skip
a stroke every so often to lift my head out of the water and site the
next turn buoy. I usually find myself off course by a few yards and
need to make corrections. This costs me time from being off course
and from skipping a stroke. So, I had this idea to take apart an old
digital camera or picture phone and mount the camera part to the back
of my head and attach the LCD part in front of my goggles.
Sound crazy? I did a Google search and found that someone has
patented the same idea...
Any other ideas? Am I crazy?
how close can you focus your eyes?
will the extra drag caused by this aparatus slow you down.
maybe an optical solution, like an L-shaperd periscope would be
a better solution?
jasen
Doesn't bathtub caulk use acetic acid to cure, like the original
silicone RTV?
some do, some don't.
If shopping at a hardware place it's best to go with stuff that's
labeled co-poylmer or neutral cure.
if not:
Dow-Corning, GE, etc. make some stuff specially for electronics.
Bye.
Jasen
