Nrf24l01 pa+lna current consumption
Ankish
Aug 4, 2017
I am using nrf24l01 for data transmission bit not getting the desired range even after setting the rate to 250kbps and power setting to 0db.when i break vcc and introduced a ameter it only showing 3ma of current which is not valid as per its datasheet don't know what is the problem.
kellys_eye
Jun 25, 2010
6,512
Sure about the current consumption? The data sheet shows Ivdd(avg) as 0.12mA for the -6dB output level and in burst mode (not knowing what mode you're using of course...).
What is your 'desired range'? and what is the terrain between tx and rx?
