Old IC Datasheet
Hey everybody,
I was wondering if anyone can help me find the datasheet for the
MCM5003AL (by Motorola) or point me to any place where I might be able
to find it, whether a book or online or by any other method.
Thank you
Tilmann Reh
According to <http://www.datasheets.org.uk/specsheet.php?part=MCM5003AL>
this is a 64x8 Bit bipolar PROM in a DIP24 package.
From the density, this must have been in the 70s... I don't have such
old memory data books at hand; even my old Fairchild bipolar memory data
book of 1980 starts with 1Kx8...
It's also unlikely you'll get anything online. However, maybe you can
get some information about a pin compatible device of another maker, if
you just need the pinout details and some basic specs for error tracking.
Tilmann
Tilmann
I tried looking for a pin compatible device but unfortunately the
closest I came to it was the 74S475 which is not exactly pin
compatible. I just need the pinout of the IC to be able to map it to
another newer more available one.
I got the pinout for the chip from an old version of DATA PAL but some
of the labels don't make much sense. There's a pin that says "H" and
it's in the place of the GND so I guess it's a ground. But there are
two pins that say G2, does anyone have any idea what that means?
Tilmann Reh
Look at the circuit the device was in: is that pin connected to ground?
But there are
The label G is often used for global enable lines.
Maybe that device has several (maybe different) enable (or chip select)
inputs? (like the 74138, for example - one active low, two active high.)
You should check where these pins are connected to. Maybe they are
simply tied to constant voltages (VCC or GND).
Tilmann
Martin Siegwarth
Hey everybody,
Thank you
Please look at
http://www.datasheet4u.com/
Yesterday I asked for the part, today they had it!
Martin
Tilmann Reh
Martin said:
Please look at
Wow - that's good service.
Now it's also clear that G1 and G2 are ground pins, which are also used
for programming the fuse matrix (at least G2, from the maximum voltages
specs).
Tilmann
Y
YD
Hey everybody,
Thank you
http://www.datasheetarchive.com is the one I most frequently use.
- YD.
