Old Marantz receiver make popping and hissing sounds no matter what
davidlaska
I have had it for decades but I do not want to give it up because it
works fine withstand the popping and hissing it does in all modes
except off. Is it over for it?
Mark D. Zacharias
It's fixable - get it to a shop that knows these things. Likely it's only
doing it on one channel, and this in turn would most likely be a noisy
transistor - they had a few problems with those, like 2SC458 and 2SC1213 and
the like. Can also be caused by a bad coupling capacitor, or if it's making
the static on both channels, could be an arcing power switch - although this
would cause interference on nearby AM radios and cause the dial lights to
flash and dim.
Mark Z.
James Sweet
flash and dim.
Mark Z.
I had an intermittent problem exactly like this on an old Wards
receiver, problem turned out to be a bad mosfet transistor in the preamp
section. Since mine was intermittent I was able to track it down with
some freeze spray.
Trevor Wilson
**The lack of actual information you've provided is simply breath-taking. At
a very minimum, here's what you need to supply:
Model Number
If the fault is input dependent.
If the fault is volume control level dependent.
If the fault is tone control dependent.
Does it occur after a period of time, or immediately?
Etc.
davidlaska
Model Number
Etc.
All answers are 'no' and it is in one channel. model number #4415
Mark D. Zacharias
At
Model Number
Etc.
The 4415 sounds like one of their smaller quad units, some of which used
rather unusual driver IC's. I don't remember the part number, but I've got a
few in a parts drawer at work. Can't say if thhis goes in yours, or if this
is your problem.
Mark Z.
davidlaska
Question 4 is not a yes or no answer, is it?
You are correct, and thanks for keeping me on the path...
I will find a an old 8-track receiver to power my speakers...
davidlaska
I will use a set of these made in China for computer speaker needs.
However, I will miss my last receiver ( the Marantz four channel) that
has survived with me ( I am 48).
davidlaska
I did not mention or really notice that it was one channel doing the
noise. Since you pointed out that attention to detail helps if
posting to this forum, I paid attention and realized it is one of the
two channels bothering me. So I disconnected that speaker and the
noise is gone (along with stereo sound).
Thanks for pointing out the obvious, I have computer sound without
that terrible noise.
Thanks to everyone who replied, I realized that I could use one
channel for now. I do not want to get into replacing parts for now.
