Older Model Hitachi TV MT-2870
Barbd
Nov 22, 2021
How low a temperature can I operate this TV at? We have it in the garage, in the winter we try and keep the garage around 50F to keep things from freezing. Can I safely operate the old TV at this temperature? Thanks for any input on this.
bertus
3,877
Its more the humidity that can cause troubles.
When the TV has a CRT tube, there is high voltage that can break at high humidity.
Bertus
Barbd
Nov 22, 2021
Thanks Bertus, so if condensation is created from the tube warming is that an issue?
73's de Edd
Aug 21, 2015
3,730
That sets kine / picture tube is of such a LARGE mass, compared to the low level heat that it can / and will s. .l . o . w . l . y create is not a problem.
Your worst case situation, is if you were to take that, WELL CHILLED tv into the heated house and then immediately turn it on.
Remember . . . . . cold eyeglasses . . . . .introduced into a WARM environs ?
