Olympus C-700 Service Manual or Schematic?
F
Fred
Buster!! You are a fine and wonderful fellow!!! This is a great help! If
you would like to send me your snail mail address, I will gladly drop
something in the mail to you.
[email protected]
Fred
Buster
Thanks for the offer, but they are free online to dealers. If you need
any others, let me know.
Buster
Christopher Pollard
How similar is the c-750? And which is the bit that retains the date/time etc.
while changing the batteries?
Chris Pollard
CG Internet café, Tagum City, Philippines
http://www.cginternet.net
Buster
There is usually a capacitor on one of the boards that holds a charge
long enough to change batteries.
Buster
Christopher Pollard
That's what I figured. The strange thing is that it remembers some of the
settings, but not all of them. The other strange thing is that if started losing
them (the settings) after I did a firmware upgrade...
It might still be under waranty, so I will probably let the experts look at it.
I'm not as sharp as I used to be. :-(
Chris Pollard
K
Ken Weitzel
Hi Chris...
Hesitate to offer such a silly yet possible solution, but...
Is it possible that your firmware upgrade reset some of your
option settings, and you need to change your "all reset" ?
Camera in P or A/S/M mode; then:
Menu > Mode menu > Set > All Reset (on/off)
Take care.
Ken
Christopher Pollard
It's ok...
The 'all reset' is off. but goes back to the default "on" when I swap batteries.
The most annoying is the loss of time/date information. If it were an "all
reset" problem, the time and date should remain correct...
Thanks anyway.
From memory, the settings I need to put back to my preferred way are:
startup sound, default is on, I like off.
button sound, likewise
time/date, back to zero
picture quality setting.
all reset, back to "on"
full time af, back to "off"
However, custom button remains set to macro. I'm sure that's not the default
My mode is also still ok.
Bizarre
Chris Pollard
Big Bill
It's ok...
Thanks anyway.
Bizarre
I will sugest that he capicator that retains the power for the BIOS is
going bad. When you change batteries, it's not holding enough power
for long enough to maintain all settings; the fact that *some* change
every time while others don't seems to indicate this.
F
Fred
Buster, is mine the kind of problem you might be able to work on ?
Buster
Sorry, most of our digital camera repairs end up going to the
manufacturer, unless they are an obviously broken external piece. The
older the camera, the less time available w/o batteries before it
forgets. My old D450 (3 years old) forgets in about 20 minutes. The
current cameras seem to last a day or two. Have an extra set of
batteries on hand and swap them when you need to charge.
Buster
Christopher Pollard
My 750 is less than a year old, and I have two sets of NiMH cells.
I can swap them over in under 10 seconds but still it forgets.
I even tried opening the cover and closing it again in 2 seconds, it forgot.
As it works otherwise, I don't want to send it away for repair just yet. But I
have a D70 on my Christmas list, so once I have that then I can manage without
it for a while.
Chris Pollard
W
William Graham
forgot.
They usually accomplish this with a fairly large (electrically) capacitor
across the battery. While the batteries are removed, the voltage necessary
to preserve the memory corcuits (which require a very small amount of
current) is maintained by the capacitor. If this capacitor is broken, or
disconnected from the battery output connections, then the camera will work
normally, but fail to hold its memory while you are changing batteries....I
would think that this would be very easy to fix, and it should be a cheap
repair bill......
James Horn
Buster - would you have access to the D-460 camera drawings? Many
thanks!!
Jim Horn
Rudy Benner
The downloaded file is corrupt. I tried twice.
Buster
You're right! My directory was full, and the file didn't d/l
completely. Try it again.
Buster
CSM1
Is it not interesting how well the Japanese can spell.
EXPRODED PARTS DIAGRAM
The title of the PDF.
F
Fred
James Horn said:
*** THANK YOU - THANK YOU ***
And a fine Christmas and New Year to you, Buster - and to Fred for
starting this discussion - and the rest of the group participants.
Thank you!
Jim Horn
Thanks, Jim, and same back to you ... and to all the other fine and friendly
folks who tak the time to help folks with questions.
Fred
