Onkyo receiver problem
Ok, I got my hands on an Onkyo TX-850 receiver. The problem with it is,
it refuses to turn on/stays in standby mode. BUT if I hairdry the
electrolytic caps or leave the unit alone for about 24 hours, it will
power on normally and work fine for a few minutes.
So, is there a good chance that replacing the caps will fix the
problem?
I do have the service manual for this just in case.
Jack
problem?
I would seem like a cap problem. Usuallu the might work, if you heat them.
However it might be just one bad cap. Use of a ESR meter would simpify this
operation.
JMK
Shoreline Electronics
I just had one of these a few months ago...this was the fix!
Text pasted from WinSTIPS 2.0
http://www.ServiceSoftware.com
ONKYO TX850
Front Panel Display Dead
Art Bevilacqua
The Problem Turned Out To Be A .022 Ufd Cap At The Collector Of The Reset
Transistor, Nearly Completely Shorted And Pulling Down That Reset Line To
Zero Volts. This Cap Was On The Front Panel, But Was Soldered Onto The Back,
Directly To The Traces, And Held Steady By Everyone's Favorite Glue Junk.
Jeff Stielau
Shoreline Electronics Repair
344 East Main Street
Clinton,CT 06413
860-399-1861
860-664-3535 (fax)
[email protected]
