online calculator or formula applicable to gauge less than 50 SWG ?
N
N_Cook
All online and my tables stop at 50 SWG. I don't know if the standard copper
resistivity formula breaks down over/less than 50 SWG. Wire in question ,
measured optically to about 0.05 mm diameter as too fine to mike up. About
19.7 ohm per metre but what is that in AWG or SWG ?
Rich Webb
I presume that the sizing conventions still hold, where the gauge value
is logarithmically related to the nominal resistance. 50 gauge should be
about 10 ohms/foot, 60 about 100 ohms/foot, etc.
19.7/meter is about 6 ohms/foot, so that should be about 48 gauge?
<clickety click>
There is a free downloadable calculator that goes to 60 gauge (and that
has other capabilities as well) over at http://www.wiretron.com/
Adrian Tuddenham
As a last resort, you could try drawing a graph of diameter or
diameter-squared against SWG, AWG or resistance. If you can find a
straight-line relationship, you can extrapolate to any value you need.
I think you can still buy graph paper, rulers and pencils in shops - if
you can find any shops. :)
Smitty Two
www.mwswire.com has tables down to 55 AWG. By my math, your resistance
figure translates to about 6000 ohms per 1000 ft., which would put it in
the 48 AWG category.
Diameter is going to vary significantly based on insulation.
..05 mm is about .002". If your micrometer can't measure that, you need a
better micrometer.
F
Franc Zabkar
Resistivity is calculated according to the following formula:
rho = R x A / L
where ...
rho = resistivity = 1.68e-8 ohms/metre for copper
R = resistance
A = cross-sectional area
L = length of material
http://en.wikipedia.org/wiki/Electrical_resistivity_and_conductivity
Therefore ...
A = rho / (R/L) = 1.68e-8 / 19.7
A = pi x r^2 = pi x (dia/2)^2
dia = 2 x sqrt(A / pi) = 2 x sqrt(1.68 x 10^-8 / 19.7 / pi)
= 0.03295 mm
http://www.google.com/search?&q=2+x+sqrt(1.68+x+10^-8+/+19.7+/+pi)
According to the tables, your wire size appears to be 49 SWG.
http://en.wikipedia.org/wiki/Standard_wire_gauge
- Franc Zabkar
Phil Allison
"Nutcase Kook"
copper
** Last time I dealt with fine enamelled wire like, that it was from the
high impedance (output end ) transducer of an Accutronics reverb unit.
But the finest I have seen is on the coil of an AKG D19 ( 200 ohms) mic
capsule - about 0.03 mm.
The D19 diaphragm was sold as a spare part and used in other mics, like the
original D12.
...... Phil
N
N_Cook
<clickety click>
Thanks for that, a useful little suite of apps
