Y
YD
- Jan 1, 1970
- 0
Why do you say that ? It's good enough for Marshall and if there's no
other volts readily available inside the box......
Graham
Well, of course it can be done, but unless you're sure of what your
doing can be a bit dangerous. If any of the bias zeners happen to fail
open there'll be much merriment.
To Eric (OP): If you want to try it, you'll need to feed the supply
circuit with about 6 mA, the TL072 draws 4 and the rest goes through
the zeners. You'll need to drop 350 volts from the +B over a 56k 5W
resistor connected between +B and the +30V point of the supply.
- YD.
