OPA2134 Vs NE5532
Shahriar
Mar 18, 2004
451
Hi
I am building a 3-way active cross over circuit. the design is based on opa2134 Dual OpAmp Which has a THD=0.00008% but in my area I can't find OPA2134. I want to use NE5532 instead.
But I couldn't find anything about NE5532 THD in Datasheet. Does anybody know how much is NE5532 THD.
ThanX in advance
Shahriar
audioguru2
Apr 6, 2004
12,026
Hi Shahriar,
Here is a site with many audio opamps tested for distortion with different loads. The author's test equipmet can measure down to "only" about 0.005% distortion so most opamps test about the same.
The old 741 opamp is shown to have terrible distortion at high audio frequencies. Some of the opamps like the TL072 have increased distortion when their output is overloaded.
http://www.dself.dsl.pipex.com/ampins/webbop/opamp.htm
Ldanielrosa1
Nov 25, 2003
316
I am not an audio enthusiast.  That much said, I think I have seen a lot of things that use 5532 because of availability.  The THD of this device will be negligible compared to any other item in the system, unless you are using $600 headphones.
