John Fields said:
Yes.
Post the resistance of the coil or the power needed to make the relay
contacts or, preferably, the manufacturer and part number.
I suppose the ring signal can be about 85 volts, but is normally about
90-100. Close enough. It would probably work best to rectify the voltage
directly with a FWB, add a 200 VDC capacitor (probably 100 uF or more), and
then drop the voltage to the relay. There is a limit to how much power can
be drawn from the phone line ring signal, so a sensitive relay might be
needed. Even better might be an optoisolator or opto-relay that will work
on 5 mA or so. In that case, a 20 uF capacitor might be OK.
If you want to use the phone line with the relay connected, you may need to
add a series capacitor so it will not draw DC current when you go off-hook.
Or you can sense the off-hook condition and disconnect the relay circuit
when the voltage drops or the line draws DC current.
Paul
