Can you trust that all your electrical outlets or the lamp with a triac are wired correctly?
If one is wired backwards then its ground is really live. If it is connected to your computer then many Amps will flow through the connection until the fuse or breaker blows.
Or maybe your grounded computer in the office connects to a sensor in the factory. The big electric motors in the factory cause a voltage drop across their wiring, raising the voltage of their ground. Again, many Amps will flow through your computer but nothing will blow except the computer.
Optocoupling is important.
